Home › Browse Forums › BARKER CABINETS › Rounded filler
Rounded filler
Posted by Michael Rotchford on January 16, 2026 at 8:32 amDo you have a rounded filler or panel that can be used to separate stacked wall cabinets to provide a more architectural look?
Chad replied 6 months ago 1 Member · 3 Replies -
We do not offer rounded fillers; all of our fillers are square by nature. If you have a photo or example of the filler you’re referring to, please share it so we can be sure we’re discussing the same thing.
Michael Rotchford
GuestJanuary 17, 2026 at 11:49 amLooking at the separation of the white wall cabinets next to the window. There is a rounded molding between the top and bottom.
Thanks
Interesting. That appears to be a transitional molding used when stacking wall cabinets on top of each other. We do not carry a molding that looks exactly like this, as our cabinets are designed to be stacked directly on one another for seamless integration and maximum space utilization.
That said, a separate aftermarket molding could likely be sourced and added if you want to achieve that specific look.
