Home Browse Forums BARKER DOOR Primer only doors
  • Primer only doors
    Posted by Patrick Manternach on October 19, 2025 at 12:23 pm
    Hello. What type of primer do you use? How many layers? Is the primed surface good to light sand and then paint with water based paint?
    Chad replied 8 months ago 1 Member · 3 Replies
    October 19, 2025 at 3:39 pm
    We use Sherwin-Williams Gallery water-based primer, two coats on the face and one coat on the back. This process allows for a quality-control inspection between coats to catch any surface blemishes early. The primer is fully compatible with virtually all water-based paints. While we recommend Sherwin-Williams topcoats for the best quality and durability, any high-quality water-based paint from a reputable manufacturer will perform well.
  • Rod Meade
    November 25, 2025 at 1:35 pm
    I need a shaker style door, summit white,
    20.5 wide x 21.75 tall . Are the frame styles 2” wide all around?
    What is the cost and approximate lead time.
    Regards,
    Rod
    November 25, 2025 at 1:46 pm
    Our doors are built with 2 5/8″ wide stiles and rails. We don’t offer a “Summit White,” but we do have Primer Only, Pure White, and Dover White. Be sure to order samples so you can review the colors in person.
    For quotes, you’ll need to enter the selected options here:
    https://www.barkerdoor.com/Shaker-Cabinet-Doors-s/39.htm
Reply to: Patrick Manternach
Hello. What type of primer do you use? How many…
