Home Browse Forums BARKER MODERN Glossy white material and grain
  • Glossy white material and grain
    Posted by KCinCA on September 9, 2025 at 6:36 pm
    Hi Chad,
    With a glossy white cabinet, is it safe to assume it doesn’t have a grain direction to consider? Specifically, I could order a vertical grain cabinet and a horizontal grain base molding and I wouldn’t see a grain to either?
    KCinCA replied 10 months, 2 weeks ago 1 Member · 2 Replies
    September 10, 2025 at 10:11 am
    Correct, the solid colors like glossy white have no grain pattern, so you can simply choose either horizontal or veridical as it will not matter. As a standard, we would recommend choosing vertical grain as this is more common (i.e. speeds up the order processing slightly).
  • KCinCA
    September 10, 2025 at 7:38 pm
Reply to: KCinCA
Hi Chad, With a glossy white cabinet, is it safe …
