Home Browse Forums BARKER CABINETS Corner cabinet dimension
  • Corner cabinet dimension
    Posted by Mandy on October 15, 2025 at 4:02 pm
    I will be ordering a corner base cabinet and having the doors modified so that they attach to the interior lazy susan and rotate with it into the cabinet box. The doors will then be flush with the corner cabinet face. Similar to the lowes cabinet in the link. For the recessed doors to be in line with the cabinets on either side, does it make sense to add one inch to the left and right dimensions (making it 37″ x 37″) of the corner cabinet? How much would that reduce the opening width?
    Thanks for your help!
    https://www.lowes.com/pd/Kitchen-Classics-35-in-H-x-30-3-4-in-W-x-23-3-4-in-D-Unfinished-Lazy-Susan-Base-Cabinet/3306684
    Mandy replied 9 months, 1 week ago 1 Member · 2 Replies
    October 16, 2025 at 11:34 am
    Yes, I would probably oversize the Base 90 cabinet by about an inch or so to ensure the interior has enough clearance for this unit.
    That said, be aware that there are a few issues with the approach of modifying the doors to attach and revolve as you’re planning. First, we cannot modify the door sizes on the cabinet case, they’re designed for a full-overlay frameless setup. Requesting them to be inset, or even smaller in width/height isn’t possible, as it would create production and design issues on our end. However, you can order new custom-sized doors from BarkerDoor.com to any dimensions you need and install them on a Barker Cabinet product as you see fit.
    Second, having the doors sit flush with the cabinet face isn’t ideal because the edge banding would be visible. We strive to cover all face edge banding wherever possible so that the only visible finish and color tone is that of the doors once the cabinets are installed. While flush doors are technically possible, it goes against our overall design approach, as banding may be slightly off from the cabinet door color/tone, just an FYI.
  • Mandy
    October 17, 2025 at 12:39 pm
    Thank you for your help!
Reply to: Mandy
Hello, I will be ordering a corner base cabinet a…
