Recent Forums BARKER CABINETS Design Wine Column Panel
    • #721
      Christa
        Sorry, I originally posted this question in the wrong area. I have purchased a panel ready 24 inch subzero wine column DEC2450W. Is there any way to order a panel with cut out?
      • #722
          Sure. This one is a bit of an odd REF as I am not seeing any specs detailing any requirement for the door panel.
          https://www.ajmadison.com/cgi-bin/ajmadison/DEC2450WL.html?srsltid=AfmBOooxqYvVSI83QawT-Kfg4-azr5l_6TFRd7doJ96LdDYHv5WVMRZK
          I checked AJ Maddison’s website for specs and see no dimensions other than the standard spec sheet.
          Click to access DEC2450W-spec_sheet.pdf
          Further research shows that they apparently sell a door panel for this model as a separate SKU.
          Stainless here. https://www.ajmadison.com/cgi-bin/ajmadison/7025337.html
          Some sort of wood solid panel here: https://www.ajmadison.com/cgi-bin/ajmadison/7031926.html
          We can certainly offer a glass door version of our appliance panel, but there would be a notch cut out on the backside that is there to accept a 1/4” thick glass panel. This might not work well here. Ideally you would want a glass door frame constructed using pocket screws and 3/4” solid stock, so a cabinet face frame essentially. This would be ideal since the ref already has glass. Unfortunately we do not sell and manufacture face frame style cabinets for about 10 years now. Basically we sold all that equipment about 12 years ago with the switch over to our frameless cabinet cases. A local shop should be able to build this rather easily so long as they sell face frame cabinets, but we would need to get some more accurate specs first.
