Recent Forums BARKER CABINETS Single cabinet
Viewing 5 reply threads
    • #2244 Reply
      Steve Pool
        Can you build a single cabinet?
        I need one cabinet that is 49 3/4″ wide by 18″ deep by 32″ tall, exterior measurements. The top would be open to accept a granite top. One side would have, behind a door 3 drawers with one being regular file size. The additional 2 drawers would be equal in size as appropriate for the remainder of the verticle space. On the right side behind a door would be 2 adjustable shelves. The 2 exterior doors would be equal in size allowing for standard-size doors for a cabinet of this size. The cabinet would be white. The bottom toe kick area would be flat with no indent. The 2 doors would not be drilled for handles.
        • This topic was modified 1 year, 1 month ago by ChadBarker.
      • #2245 Reply
          You would need to use multiple base cabinets placed side by side to achieve 49.75″ total width. Sound’s like the single door base cabinet with rollouts behind the door would be your best bet here: https://www.barkercabinets.com/1-door-base-cabinet-p/b1d.htm
          • This reply was modified 1 year, 1 month ago by ChadBarker.
        • #2276 Reply
          Stepold54
            I need cabinets with pull out drawers and a file drawer. Do you have a solution?
          • #2277 Reply
            Stepold54
              …On the inside of the cabinet. Thank you.
            • #2284 Reply
              Stepold54
                Are you still responding? Thanks.
              • #2288 Reply
                  We have limited options for files drawers. Here is one:
                  https://www.barkercabinets.com/2-drawer-file-cabinet-letter-sized-files-p/b2drfilecabinet.htm
                  As for rollouts behind the doors, you can select rollouts as an addition to any of our base door cabinets. Note there is a dropdown option that lists “pull out shelves” as an option:
                  https://www.barkercabinets.com/2-door-base-cabinet-p/b2d.htm
              Reply To: Single cabinet
