Recent › Forums › BARKER CABINETS › No door tall pantry cabinet
- This topic has 3 replies, 2 voices, and was last updated 1 month ago by
DJ
Is this available under Barker? I only see it under City Cabinet, but would prefer to order all thru Barker for shipping and applicable discount purposes. Thanks
I will add this to Barker Cabinets. I just got back from vacation, so give me a few days. Thanks!
Can I ask for clarification of what DJ means? Isn’t the TEXPOSED what you are talking about? Or do you mean that you want roll out shelves but just no door? I ask because I was actually wondering if there was a way to do a TEXPOSED but have a rollout shelf (or two) added to the bottom, but I didn’t know if the rollout shelves could be made in the same color as the cabinet as opposed to maple veneer.
The TEXPOSED cabinet has a finished interior and is designed to be visible, with a matching interior wood species and finish that aligns with the cabinet face and surrounding doors and drawer fronts.
Our standard interior material is prefinished clear-coated maple, which typically does not look ideal next to darker finishes like cherry, maple, walnut, etc. The TEXPOSED option is more expensive because the interior can be ordered in cherry with a matching stain to the doors.
The cabinet DJ requested is the less expensive version of the TREXPOSED with a prefinished maple interior and no door. This version is not intended to be visible as-is and should have a door, appliance, or other covering added to the front to conceal the interior.
In some cases, customers use another manufacturer’s doors and install them on our cabinet cases. This allows them to match an existing kitchen without replacing all cabinets or when adding a few units to an existing run.
