Recent Forums CITY CABINETS Hafele Magic Corner
    • #2505 Reply
      Ben
        Hi, is there any possibility of either purchasing the Hafele Magic Corner 2 with you instead of the original version, or being discounted the Hafele portion of the cabinet while still buying the cabinet and then purchasing the Hafele Magic Corner myself? Also, the Hafele Magic corner 1 has two different tray capacities on their website for either 1001 sq.in. or 1138 sq.in. Which one comes with the City Cabinets package? I know it’s not a ton of extra storage, but I’d prefer the larger option.
        From the Hafele Magic Corner 1 website: “Storage capacity: 1,001 in2 using 295 mm x 470 mm (11 5/8″ x 18 1/2″) front and 390 mm x 470 mm (15 3/8″ x 18 1/2″) back 1,138 in2 using 390 mm x 470 mm (15 3/8″ x 18 1/2″) front and back”
        Thanks in advance!
      • #2508 Reply
          Best to simply order the non-magic corner blind corner cabinet and then simply add the magic corner 2 to that cabinet. It would not be possible to pick apart an already integrated and designed cabinet as the mounting holes and various other attributes would be different. Adding the other magic corner to a blind corner base cabinet should not be too difficult to do on site as that one does not attach to the door.
          I will look up the tray models when I get back to the office. On mobile now.
        • #2513 Reply
            Here are the exact ordering codes from Häfele. We use the Maple/Champagne shelves. Please note that you must use one set of 11 5/8″ depth shelves and one set of 15 3/8″ depth shelves.
            If both sets are ordered in the larger depth, the shelves will collide (see second pic). This setup is only valid for the Magic Corner I, as I have not worked with the Magic Corner II.
          • #2522 Reply
            Ben
              I see, thanks. I think I’ll just stick with the magic corner product that you provide. It looks like it will work well.
          Reply To: Hafele Magic Corner
