Recent Forums BARKER CABINETS floating shelves
    • #2393
      Fran
        Does Barker make custom floating shelves? I am looking for walnut, clearcoat, to match the rest of my order. Lengths needed are just over 3ft. each, and one 20″.
      • #2394
          Currently we don’t carry a floating shelf product as the mounting hardware has yet to be sourced. You can certainly order 1.5” thick end panels and simply turn them on there side (they are banded on all four edges) and mount them using aftermarket harder here:
          https://www.barkercabinets.com/product-p/wfethick.htm
          • #2398
            Fran
              Thanks for your reply. This the end panel you mentioned finished on both sides?
              And thinking.. if I wanted the shelves thicker than 1.5″, would using the tall wide stile end panels work (horizontally)?
              Are these wide stiles finished on both sides? I am not worried about ends as they will abut cabinets and/or wall.
          • #2395
              • #2402
                Fran
                  Are these wide stile panels finished on both sides? I am not worried about ends as they will abut cabinets and/or wall.
              • #2403
                  Yes, the base and wall THICK end panels are finished on all sides, although we will etch the job # into the top or bottom of the part (this has to be done in order to track the parts though finishing). It is an etching and not super noticeable.
                  Tall wide end panels are not finished on the top and bottom edges and will have raw plywood exposed.
