Recent Forums BARKER CABINETS exterior of finished interior cabinet
    • #4258 Reply
      Darlene
        What does the exterior of this cabinet look like – do I still need a finished end? thanks!
        0 door 1 drawer exposed interior base cabinet (interior will the match wood type and finish chosen for the face of the cabinet)
        https://www.barkercabinets.com/0-door-1-drawer-exposed-interior-base-cabinet-p/bexposed1dr.htm
      • #4266 Reply
          All of our cabinets require a finished end panel to cover the outside of the cabinet cases. Otherwise, the construction holes would be visible. The veneer on the outside of the cabinet, while matching the interior, is not the same grade and is not covered under warranty for blemishes, as it is not intended to be a normally visible surface.
      Reply To: Reply #4266 in exterior of finished interior cabinet
