All of our cabinets require a finished end panel to cover the outside of the cabinet cases. Otherwise, the construction holes would be visible. The veneer on the outside of the cabinet, while matching the interior, is not the same grade and is not covered under warranty for blemishes, as it is not intended to be a normally visible surface.
