Recent Forums BARKER CABINETS Doors on WEXPOSEDBOOKCASE?
    • #4548 Reply
      DVDiva
        Can you add doors to a WEXPOSEDBOOKCASE? I saw that you have the usual pull down for “doors” but I wasn’t sure if that was meant for the interior finish of the bookcase.
        I am thinking about creating a base cabinet with a counter and then placing this WEXPOSEDBOOKCASE over it, so that the countertop is still exposed but that there would be a closed cabinet above it. This is for a niche area, so the base cabinet and bookcase cabinet would only be about 16″ deep. I am planning to put a small appliance on it, so I wanted a countertop to make it easier to clear and not the bottom of a cabinet. Thanks.
      • #4553 Reply
          I will need to add that one to make it correct.
          Assuming you want no cabinet bottom/deck, then yes, I will need to make a separate product, as the doors need a COUNTERTOPDROP reveal of 1/4″ from the bottom of the doors to the top of the countertop.
          This is a bit larger than our standard 1/8″ gap and will ensure the doors do not rub the countertop.
          I will add this next week.
        • #4560 Reply
          DVDiva
            Wow, thanks Chad! Yeah, I was thinking of no cabinet bottom/deck but with doors. I don’t know if you should create a whole separate product just for me though! I’m still trying to figure out options of what to do and would hate for you to make that special!
          • #4581 Reply
              If you are asking about it, then there are probably other current and future customers who will want that cabinet as well 😉
              It could be a good addition to expand the available offerings.
          Reply To: Doors on WEXPOSEDBOOKCASE?
