Recent Forums BARKER DOOR Blum Drawer Slides
    • #3745
      Jason Jacoby
        How should I size my drawer boxes when using Blum Tandem slides? They specify opening width minus 13/32″, but ordering boxes is limited to 1/16″ increments. Thanks!
      • #3760
          We allow 3/16″ of clearance on each side of the drawer box, which means the drawer box itself is 3/8″ narrower than the cabinet opening where it will be installed.
          Please review the videos and written instructions at the following link before placing your order. This sizing formula applies only to drawer boxes made from 5/8″ thick material.
          If another vendor has suggested a 1/32″ increment, they are likely using a different drawer box material or construction method, which slightly changes the required opening size. Drawer box material thickness, slide model, and hardware all affect sizing, so we recommend keeping things simple and not mixing measurement instructions from different vendors, as that can lead to sizing errors.
          https://www.barkerdoor.com/Blum-Tandem-Plus-Blumotion-Drawer-Guides-s/118.htm
          • #3765
            Jason Jacoby
              The 13/32″ dimension is taken straight from the Blum instructions on their website.
              Blum Tandem Drawer Box Specifications
              I’m sure it’s a simple matter of converting metric to inches, as 13/32″ is slightly closer to 10mm than 3/8″.
              Thanks for confirming!
