Recent Forums BARKER MODERN B1DPULLOUTTRASHSINGLEM – ok to notch cabinet to run sink vent through back of?
Viewing 4 reply threads
    • #3910 Reply
      Scottanddogs
        I am having trouble running the vent through the wall behind my kitchen sink due to a window behind sink and only a 2×4 wall.
        We are thinking of swapping the position of the dishwasher and pullout trash cabinet to make room for the vent (design attached)
        question:
        is it ok to notch the B1DPULLOUTTRASHSINGLEM cabinet to run a 2” vent through the back of this cabinet?
        any suggestions of how you see people handle something like this?
        thank you
        Scott
      • #3913 Reply
          Yes, the cabinets are plywood and can be modified as needed. I actually prefer pulling vents into the cabinet case and then routing them to a back wall. This allows for access in case anything ever needs to be serviced.
          We run into this often in laundry room applications where a dryer needs to vent to the side but a cabinet is in the way. In those cases, we bring the ducting into the cabinet and route it as required.
          If you are referring to a heating and cooling vent, the same concept applies. We typically notch the toe-kick and install a register in the cabinet face before the toe-kick skin is installed. This is very common and easy to cut on site. The plywood construction allows for significant modification without compromising the strength of the cabinet.
        • #3917 Reply
          Scottanddogs
            This is for the sink drain vent (2”). Want to make sure we get the underground plumbing correct (which we are doing now) before I order the cabinets. I need to get the vent from the sink drain to the existing vertical vent.
            I realized I included the wrong product code on my original post.
            For a 18” wide 34.5” tall B0DPULLOUTTRASHM, can you confirm my understanding of the cabinet construction?
            side panels are 3/4” each
            back panel is 3/4”? How tall is the top panel in back of the cabinet I see in the cabinet (attached)? What is the elevation of it?
            So, for a cabinet depth of 24”, I will have:
            24” – 3/4” (rear piece) = 23.25” clear depth inside cabinet (without trash cans inside)
            Height of 34.5”, I will have:
            34.5” – 4” (toe kick) – 3/4’ (top) = 29.75” clear height inside cabinet
            Width of 18”, I will have:
            16.5” clear width inside cabinet (without trash cans inside)
          • #3937 Reply
              Correct. Please see the attached drawings showing each dimension. Let me know if you need anything else.
            • #3939 Reply
              Scottanddogs
                thank you so much
            Reply To: B1DPULLOUTTRASHSINGLEM – ok to notch cabinet to run sink vent through back of?
