Home › Browse Forums › BARKER CABINETS › Appliance Cabinet Sizing › wolf warming drawer
wolf warming drawer
Posted by Talen on June 27, 2026 at 11:43 pmHello,
I’m looking to order the WAPPLIANCECASE for a wolf warming drawer that should be 9.25″ tall.
Your site only allows me to order a min of 10″ tall.
Are we able to order the 9.25″?
Thank YouChad replied 3 months, 1 week ago 2 Members · 3 Replies -
Yes, you can request a change to the cabinet height. Order the cabinet at the smallest available height, such as 10 inches, then note at checkout that you would like the height changed to 9.25 inches before production.
We will make the adjustment on the backend before production begins. Just be sure to include the request in the order notes.
Would it be better to order one tall WAPPLIANCECASE that contains all three stacked Wolf appliances, or three separate WAPPLIANCECASE cabinets stacked together?
The appliances are a Wolf warming drawer, Wolf drop-down microwave, and Wolf convection steam oven. I want the cleanest installation with proper support between each unit.
If one tall case is recommended, can it be configured with separate fixed support shelves/decks for each appliance opening, sized to the Wolf specs? Also, are those decks strong enough for the Wolf required support loads, or would they need reinforcement?
There really isn’t a good or accurate way to order a single tall appliance cabinet and ensure all of the fixed shelves end up in the correct positions. In addition, most appliances require approximately a 3/4″ overlap at both the top and bottom of the opening, which means you would still need doubled-up fixed shelves between the appliance openings.
The simplest, strongest, and safest approach is to order each appliance cabinet as a separate unit and then stack them together during installation. This creates a much more manageable assembly, makes installation easier, and allows individual sections to be replaced or modified in the future without having to rebuild the entire cabinet.
