Home › Browse Forums › BARKER CABINETS › Wide Stile Mitered End Caps
  • Wide Stile Mitered End Caps
    Posted by Carson Volker on February 15, 2025 at 1:40 pm
    I’m putting in an order for kitchen cabinets and I’m looking at the Island example: “Island with mitered wide stile end caps”. I need to add one of the end caps (BFEWIDESTILEMITERED) to my cart, but I can’t seem to find that part anywhere. I need this piece to be 41.25″ to accommodate a 26″ and 14″ deep cabinet back to back in an Island. The only one I can find that is similar is the wide stile end cap with butt joint, but those only come in depths on the inch or 5/8″ increments (eg. 24″ or 24 5/8″ etc).
    Chad replied 1 year, 7 months ago 1 Member · 1 Reply
    February 15, 2025 at 2:21 pm
    The mitered version was replaced with the butt joint version at the link below.
    https://www.barkercabinets.com/Base-Finished-End-Panel-SLAB-WIDE-STILE-p/bfewide.htm
    We can modify the depth to whatever you need. Simply order it at 41″, then request that the depth be changed to 41.25″ in the order notes at checkout (credit card screen). We will make the change manually before production starts. Just do not forget the order notes.
Reply to: Carson Volker
I’m putting in an order for kitchen cabinet…
