Home › Browse Forums › BARKER MODERN › Wall cabinets
Wall cabinets
Posted by Steve Troyer on September 30, 2026 at 2:11 pmI was looking at Barker Cabinets, but after looking at what style finish we want, Barker Modern may be a better fit. Barker Cabinets and City Cabinets offer a 60″ cabinet (we have 10′ ceilings) but I cannot locate wall cabinets in 60″ in Barker Modern. Are they available?
Chad replied 1 month, 2 weeks ago 3 Members · 6 Replies -
At 60″ tall, we really consider that a tall cabinet. There has always been a little overlap in that range. Barker Cabinets originally allowed taller wall and base cabinets, but we have since brought those back to a 48″ maximum height.
Some wall cabinets are still available up to 60″, and our new line being released shortly will bring the 60″ maximum back to the site.
For the Modern line, you would simply switch to a tall cabinet and order it with no toe kick to achieve essentially the same result.
Steve Troyer
GuestOctober 4, 2026 at 8:15 amHow many door hinges would be on a 60″ door?
Steve Troyer
GuestOctober 10, 2026 at 8:53 amThanks for the info. I have one tall cabinet that needs to be 42″ wide the widest available that I can find in the tall cabinets is 36″ wide. Can I add a note in the comments section to make this 42″ wide to be modified in production? I could order 2-21″ cabinets if I had to, but prefer 1 single cabinet.
Yes, you can add a note at checkout. That is getting fairly wide, but as long as the wall cabinet is reasonably deep, you should be fine in terms of shelf sag.
Not the rep, but I ran into something similar on a pantry wall. Before you commit to two 21″ boxes, it might be worth asking Chad whether a 42″ width would get two doors instead of one. At that size I’d expect a pair of 21″ doors either way, so the front would look about the same as two cabinets side by side. The real difference is the inside: one box gives you full-width shelves with no center partition, which is nice for trays or bigger items.
