Home › Browse Forums › BARKER CABINETS › trash pullouts
  • trash pullouts
    Posted by suzi ekvall on February 4, 2026 at 10:06 am
    I need a trash pullout that is less than 18″. I can go 15.5 or 16. I don’t see that Barker makes one of that size. Can i just use a base cabinet of the appropriate size and get an after market trash pullout?
    Annie replied 5 months ago 2 Members · 4 Replies
    February 4, 2026 at 12:10 pm
    Sure, we offer 18 inch and 15 inch wide pullout trash cabinets. A size in between is not possible, as the pullout trash units are fixed width and cannot be custom sized.
    You can use a single door cabinet with a drawer above, then install an aftermarket trash pullout in the lower opening. We recommend a floor mounted pullout for best stability.
    The interior width of our base cabinets is approximately 1.5 inches less than the listed cabinet width. For example, a 16 inch wide cabinet will have about 14.5 inches of usable interior width behind the door.
  • Annie
    May 7, 2026 at 9:08 pm
    If we want to use a third party trash or pullout system, and we order a B1D, it looks like I have to choose a hinge side, but I don’t want hinges in this case. Do I just add a note later in the order process to not drill any holes for these doors?
    I will be ordering other B1Ds, so I wasn’t sure how exactly to distinguish them (or maybe it doesn’t matter – but I will need hinges on some of those B1Ds).
    May 8, 2026 at 11:51 am
    Sure, just request that the B1D be made without drilling the hinge cups in the order notes at checkout. This is fine and an easy change.
    If you have a lot of single-door cabinets, please add this one odd B1D cabinet to the end of the order so it is by itself as a quantity of one.
    It is much easier to change a single line item with a quantity of one than it is to break apart a quantity of two cabinets into two separate line items. That creates a mess on our end, but keeping the non-hinged cabinet as its own line item makes it easy.
  • Annie
    May 8, 2026 at 10:13 pm
    Got it and will do – thanks!
Reply to: suzi ekvall
I need a trash pullout that is less than 18″…
