Home › Browse Forums › CITY CABINETS › Staining and Sealing
Posted by Holly on October 26, 2026 at 11:08 amHi there, we decided to do the staining ourselves so we could try several samples at home and decide which would work best.
Do you recommend staining and sealing before assembly? Or after?
Any recommendations on the best type of stain and sealer to use?Chad replied 3 weeks, 6 days ago 2 Members · 1 Reply -
1 Reply
I would recommend applying the finish after the cabinets have been installed, if at all possible. I took this approach with the painted cabinets on my last project, and the results were noticeably better, especially around the millwork, crown molding, and base molding. I was able to fill small gaps and imperfections at the seams without having to start over with a new piece just to achieve a better miter. Finishing everything after installation allowed for a much cleaner, more seamless appearance.
The same general principle applies to doors and drawer fronts. I always recommend waiting as long as possible before installing them. Ideally, keep them safely stored in another room until all the subcontractors have finished their work and the project is ready for final cleanup. Contractors can be pretty rough on cabinets, and installing finished doors and drawer fronts too early unnecessarily exposes them to scratches, dents, and other damage.
As for staining, I would be very cautious and probably wouldn’t attempt it unless you have considerable experience with the process. Applying a clear coat is relatively straightforward and forgiving, but staining is an entirely different story. I’ve seen plenty of beautiful woodwork ruined by improper staining techniques, and once the stain has been applied unevenly or incorrectly, correcting the damage can be extremely difficult, if not impossible without extensive sanding and refinishing.
My recommendation would be to choose a wood species that naturally has the color and appearance you’re looking for, then apply a clear coat to protect and enhance it. If you want a darker appearance, consider walnut. If you prefer something lighter, maple is a great option. There are plenty of beautiful natural wood tones available, and working with the natural characteristics of the wood generally produces a more consistent, predictable, and attractive result than trying to achieve that appearance through staining.
