Home › Browse Forums › BARKER CABINETS › Appliance Cabinet Sizing › Single Wall Oven Base Cabinet
    April 17, 2025 at 10:32 am
    Sure, see here for how I would size the cabinet.
  • Fran
    April 18, 2025 at 6:24 am
    Thanks Chad. You suggest a 25.5″W cutout, whereas the spec sheet states maximum cutout is 25.25″W. Would you not be concerned that the opoening would be 1/4″ too wide for the oven?
    April 18, 2025 at 11:44 am
    An extra 1/4″ of opening width is minimal and generally not an issue. The more critical dimension is the oven’s face, which measures exactly 27″ wide. If necessary, you can easily add a small block, shim, or spacer—typically only required when securing the wall oven to the cabinet case with a set screw.
    Appliance manufacturers often recommend a bit of extra space to ensure the unit fits properly within the cabinet. These guidelines are usually based on face frame cabinet construction. With frameless cabinets, which use 3/4″ thick side panels, it’s common to use small spacers during installation to accommodate appliance fitment on site.
Reply to: Fran
For a single wall oven base could you please help…
