Home › Browse Forums › BARKER DOOR › shaker slab front drawers
  • shaker slab front drawers
    Posted by Alaison on January 5, 2026 at 12:42 pm
    Hello. I see the disclaimer on the shaker flat panel drawers that solid wood drawers over 10″ wide are prone to cracking and warping. Is there a way to have these made in MDF or is there a wood that is less prone to warping? I have several drawer fronts that are 25-27″ in width (6″ height) that I’m looking to order. They will be painted, not stained. Thank you.
    Chad replied 10 months, 3 weeks ago 1 Member · 1 Reply
    January 5, 2026 at 12:47 pm
    As long as you keep them at 6″ tall, you will be fine with any width you select, including the 25″–27″ range you mentioned. Issues typically only arise with very large pieces, such as a 24″ wide by 24″ tall slab drawer front. At 6″ tall, this size is perfectly acceptable and should not present any problems.
Reply to: Alaison
Hello. I see the disclaimer on the shaker flat pa…
