Home › Browse Forums › BARKER MODERN › Scribe Molding
Scribe Molding
Posted by Dee on December 6, 2025 at 12:31 pmIs scribe molding available in the Barker Modern line?
Chad replied 11 months, 3 weeks ago 1 Member · 1 Reply -
1 Reply
Scribe for the Modern line uses the same core material as the cabinet doors. The textured laminate is pressed over an MDF/PBC core, which must remain soft enough for the embossing process to form the texture properly. Because of this core composition, ripping the material into a thin 1/4″ strip becomes extremely fragile, it would almost certainly crack during fabrication or break in shipping. For this reason, we do not offer it as a standard product on the website.
I have made it successfully on-site, but it requires access to a table saw. Order our square trim molding — the 2″ x 90″ millwork piece typically used for valances or simple crown molding and rip it lengthwise to create roughly 1″ wide strips. Then split those again to yield four scribe moldings out of a single stick. It takes a bit of cutting, but you get four usable scribes from one piece, and they ship safely without the risk of breaking.
