Home › Browse Forums › BARKER DOOR › Sanding question
  • Sanding question
    Posted by K. Henson on March 28, 2026 at 11:44 am
    Are the cross grain marks sanded out of your paint grade doors?
    Laura replied 1 month, 1 week ago 4 Members · 4 Replies
    March 28, 2026 at 12:03 pm
    Cross-grain scratches are not an issue. All doors go through a final orbital sanding step, so any cross-grain marks are minimal, microscopic, and nearly invisible. That said, if you are ordering paint-grade doors, the primer and paint will cover anything even remotely noticeable. We have even tested deep scratches prior to priming, and the primer virtually eliminated those marks. All doors are sanded to the same standard as stain-grade products, so paint-grade doors receive the same level of preparation.
  • hannahz5
    May 12, 2026 at 9:55 pm
    I have at least two doors with a lot of cross grain saw marks. And this is after I’ve sanded in the direction of the grain a few times.
    May 13, 2026 at 1:55 pm
    Looks like it may be a glue issue under the veneer where the substrate and veneer are glued together. Is it wavy to the touch, almost like the veneer is sitting on an uneven substrate?
    Sanding would not cause an issue like this. unless its from the mill like this, especially if this is a slab plywood cabinet door or finished end panel, since the veneer is very thin.
    What material was selected for the door wood type? If this is paint grade, it would be treated differently than a premium select material intended for stained or clear-coated doors.
    Do you have an order number I can look up?
  • Laura
    October 13, 2026 at 5:29 am
    Henson, from what I’ve seen it depends on the door. A final orbital sand gets most of them, but deeper marks can still show once primer is on, especially with a glossier paint. I’d check each door under a low-angle light before priming and hand sand with the grain if you spot any. Just go light if it’s veneer.
Reply to: K. Henson
Are the cross grain marks sanded out of your pain…
