Home › Browse Forums › BARKER DOOR › Ok to overlay existing center stiles on double door cabinets?
  • Ok to overlay existing center stiles on double door cabinets?
    Posted by Paige on August 21, 2025 at 6:16 am
    Our 1980s cabinets with double doors have a built-in 2-inch wide center stile. Current cabinet doors leave the stile exposed. The doors have a lip (rabbet?) so part of the door fits inside the frame. I will be ordering shaker doors.
    Is it OK to leave the center stile and measure for full overlay? Current doors are hung with with hinges on the same side (e.g. right side) so they both swing open left to right. I plan to to put hinges on opposite sides so doors meet and close in the middle against the stile.
    Chad replied 1 year, 3 months ago 1 Member · 1 Reply
    August 23, 2025 at 7:59 am
    Yes, you can overlap the center stile as much as needed to cover that area. The only critical section is the hinge side, since the hinge and overlay must align correctly (e.g., a ½” hinge-side overlay requires a ½” overlay hinge on that side).
Reply to: Paige
Our 1980s cabinets with double doors have a built…
