Home › Browse Forums › BARKER CABINETS › Modifying BDEEPFILLER
  • Modifying BDEEPFILLER
    Posted by DVDiva on May 11, 2026 at 9:23 pm
    Is there anyway to order the BDEEPFILLER as 1.5″ wide instead of 2″? I would need to order at 4 or 5 of them.
    Chad replied 5 months ago 1 Member · 1 Reply
    May 13, 2026 at 2:12 pm
    1.5″ would not be available as a modification.
    The issue is that, at 1.5″, we are unable to safely run the part through our edge banding equipment. The belt that holds the part is spaced away from the area where the banding is applied. At only 1.5″ wide, the part is barely held by the belt, which means it can shift out of alignment and potentially damage the equipment.
    2″ would be our minimum, and even that is pushing the limits.
    The best option would be to order it at 2″, then cut it down on site if needed.
Reply to: DVDiva
Is there anyway to order the BDEEPFILLER as 1.5&#…
