Home › Browse Forums › BARKER DOOR › Measuring for drawer box
  • Measuring for drawer box
    Posted by Diane on September 24, 2026 at 10:36 am
    What’s the formula for determining what size drawer box? For example, if I had a 23.5 inch wide by 5-1/16” tall opening (cabinet is 23” deep, what size box would I need? Thanks!
    Chad replied 1 month, 4 weeks ago 3 Members · 2 Replies
  • Cabinet2020
    September 28, 2026 at 12:57 am
    For a 23-1/2″ clear opening, I’d size the drawer box based on the slide manufacturer’s required side clearance rather than using a universal formula.
    For example, with slides requiring 1/2″ clearance per side, the drawer box width would be:
    23-1/2″ − 1/2″ − 1/2″ = 22-1/2″
    For the 5-1/16″ opening height, the box height depends on the slide system and how much clearance you want above and below the box. I would not make the box the full 5-1/16″ opening height.
    For the 23″ cabinet depth, check the actual usable interior depth and select the appropriate slide length. The drawer box itself doesn’t necessarily need to be 23″ deep.
    So the key is to start with the actual clear opening + slide specifications, then determine the box dimensions.
    September 28, 2026 at 10:13 am
    Correct. To add to this, we have videos and a written explanation showing how to order drawer boxes based on the Blumotion slides we carry at the link below. Please be sure to scroll to the bottom of the page to view the tutorials.
    For a quick reference on the measuring requirements for the Tandem/Movento slides, please also see the attached images as this visually explains how we would order the drawer boxes based on the opening size.
Reply to: Diane
What’s the formula for determining what size draw…
