Sure. To get a similar result, use Sherwin-Williams Gallery Clear Coat and apply two coats at about 4 to 5 mils wet thickness. A 20 sheen would be the standard sheen we use.
Sand before the first coat and again between coats. Our sanding process is automated with a Robatech Universal system, so the edges are broken evenly, but you can get essentially the same result by hand without having any issues with the veneer.
We also inspect and hand-sand each piece between steps. After that, it goes through the orbital sanding process, which helps polish the inside edges and details, removes sharp corners, and gives all of the surfaces a light scuff for proper adhesion.
Stick with higher-grit sandpaper, around 400 grit or higher, and you should be fine. The veneers may look thin, but they are American-made and thicker than a lot of the imported material you may have seen.
I would recommend sanding with 400 grit, spraying both sides, sanding again with 400 grit, and then applying the second coat. That should get you very close to the finish we provide. You can also use 300 grit without any issue. I would just stay away from anything around 220 grit or lower.
Technically, we use an AcromaPro product. AcromaPro is Sherwin-Williams’ industrial coatings division, and from what I have seen, the products are very similar. It is really nice material and extremely durable.
Clear coat is also pretty forgiving because you can always add another coat if you have an issue or need to make a repair. I would not stress too much about getting every detail perfect. If you apply too much, just sand it back and do it again.
