Home › Browse Forums › BARKER MODERN › Height of 2 door Tray Divider Wall Cabinet
  • Height of 2 door Tray Divider Wall Cabinet
    Posted by KCinCA on September 27, 2025 at 3:14 pm
    The 2 door tray divider wall cabinet shows the dividers with a shelf at the top.
    The drawing on the website shows 20″ usable space; is this adjusted for a shorter cabinet, or do I need to order a minimum height of 22.25″ to accommodate the cabinet box plus the shelf for the dividers to attach?
    If not, what is the interior usable height of the tray divider section if I were to order a 20″ tall tray divider cabinet (34″ wide)?
    Chad replied 1 year, 1 month ago 1 Member · 5 Replies
  • 5 Replies
    September 29, 2025 at 11:14 am
    We typically maintain 20″ of clear, usable space on most of our taller cabinet sizes, which works well for storing cookie sheets. If a lower height is ordered, we simply remove the shelf and run the dividers the full height, this is usually around the 24″ cabinet height mark. For a 20″ tall cabinet, you’ll have approximately 18.5″ of usable interior height.
  • Kevin
    September 29, 2025 at 10:47 pm
    I actually have a 21″ tall cabinet with dividers in production right now, so this is great info.
    September 30, 2025 at 11:27 am
    What’s your order number? I can pull up and show you the side view along with all specs listed for your exact cabinet.
    • Kevin
      October 4, 2025 at 11:08 am
      My order number is 10595. Thanks!
    October 8, 2025 at 12:42 pm
    Sure see here for how your cabinet is being built.
Reply to: KCinCA
The 2 door tray divider wall cabinet shows the di…
