Home › Browse Forums › BARKER MODERN › Glass door base cabinet shallow. Which color white?
  • Glass door base cabinet shallow. Which color white?
    Posted by pgorelik on December 26, 2025 at 10:08 am
    I’d like to use the 2 glass door base cabinet (B2DGLASSM) as the end of my island. Ideally this would be shallow (7-10″). I see that shallow depths are available on barker.com, but not on barkermodern. Is it possible to get the modern glass cabinet in shallow depth?
    The white paint used for the the doors, is it dover/pure white as used on other classic barker cabinets, or is it a different hue?
    Thank you,
    Pavel
    Chad replied 11 months ago 2 Members · 1 Reply
    December 29, 2025 at 1:34 pm
    Yes, we can manufacture a glass door cabinet down to approximately 6 inches in depth without causing any issues with hinge placement. You can place the order using the minimum depth available on the website, then request the exact depth you need in the order notes at checkout. Please be sure to include this note, as changes will not be made without it.
    For white paint on BarkerModern.com, we use the same Pure White finish shown on our other websites. This color is the closest match to the White Matte laminate offered in our laminate line.
Reply to: pgorelik
I’d like to use the 2 glass door base cabin…
