Home › Browse Forums › BARKER CABINETS › Flip up wall cabinet
  • Flip up wall cabinet
    Posted by Steve Troyer on August 15, 2026 at 10:40 am
    If I use a flip up wall cabinet setting on a countertop to use as an appliance cabinet, is there any reason I should have to use the base panel of the cabinet and just set the cabinet directly on the countertop?
    Chad replied 1 week, 1 day ago 2 Members · 3 Replies
    August 18, 2026 at 11:19 am
    Sure. For a flip-up cabinet, the bottom reveal will be approximately 1/8″. Since the door does not swing outward and instead lifts up, you should be fine installing the cabinet directly on top of the countertop.
    Regular hinged door cabinets are different. For wall cabinets with doors that swing left or right, a larger bottom reveal is needed. With the standard 1/8″ bottom reveal, hinge adjustments can occasionally cause the bottom edge of the door to rub against the countertop.
    For those applications, the bottom reveal would need to be increased, or a different cabinet/product would need to be used.
    For the flip-up cabinet, however, the standard 1/8″ reveal is fine.
  • Steve Troyer
    September 30, 2026 at 2:56 pm
    Does your answer also the same for Barker Modern Cabinets?
      October 2, 2026 at 11:09 am
      Yes, the Modern line uses the exact same reveals as the City and Barker lines. So, for a flip-up cabinet, there would be a 1/8″ reveal along the bottom.
Reply to: Steve Troyer
If I use a flip up wall cabinet setting on a coun…
