Home › Browse Forums › BARKER CABINETS › Finished bottom for wall cabinets?
  • Finished bottom for wall cabinets?
    Posted by Kenschretlen on February 21, 2026 at 5:38 am
    I am about to install my wall cabinets and was about to put a finished end on one first as I am up against some trim. As I looked at the cabinet, I realized for the first time that the bottom will have an unfinished edge from the cabinet sides where you could see the plywood construction (only for the very edges of course). Has there been any thought on a finished bottom like the finished edge? I realize that both you won’t be typically looking under the wall cabinets as well as the majority of the base is finished, but thought this was odd and that maybe I missed some finished bottom?
    Thanks
    Chad replied 6 months, 2 weeks ago 3 Members · 5 Replies
  • 5 Replies
    February 23, 2026 at 11:57 am
    Typically, we would add an under-cabinet light valance molding to the underside of the wall cabinets. This hides the light fixtures and cleans up the bottom edge of the cabinets. In this setup, the interior color or material of the cabinet case will still be visible behind the UCL molding.
    https://www.barkercabinets.com/Under-Cabinet-Lighting-Valance-s/70.htm
    You can certainly add a full skin instead. This is done by ordering an additional finished end panel or appliance panel and installing it horizontally. However, this eliminates the ability to conceal the light fixtures beneath the cabinet, so it is rarely done this way.
  • Kenschretlen
    February 23, 2026 at 2:19 pm
    As I installed the cabinets I realize that it really isn’t an issue, but I figured you’d have a solution! If I decide to do something there, I’ll add the valance as you suggested would help too for hiding any lights I may add. Thanks again for your help, and I like the forum, I searched it for my questions, so hopefully others do and find what they’re looking for.
    February 24, 2026 at 11:18 am
    All good. Thanks for your business!
  • Annie
    March 29, 2026 at 9:46 am
    I am designing wall cabinets over a toilet, so you will be able to see the bottom of the wall cabinets. I realized that the filler for the sides of the cabinets will allow you to see the gap betweent the wall cabinet and the wall, and of course, the bottom of the cabinet will be maple instead of clearcoat cherry. In this case, should I just order a finished end like you’re saying above to use that as a bottom or is there a different option?
    and should that bottom also be 5/8″ deeper of just be the same depth as the wall cabinets?
    March 30, 2026 at 12:06 pm
    Currently, yes, just order a finished end panel and lay it on its side. I will likely add a skin product to the website, but it will be built and priced the same way as a finished end panel laid horizontally, so the end result will be the same.
    https://www.barkercabinets.com/Kitchen-Wall-Finished-End-Panels-s/97.htm
Reply to: Kenschretlen
I am about to install my wall cabinets and was ab…
