Blum hardware upgrade options and hood enclosure questions
Hey Chad! Long time forum lurker, first time poster. I have a whole bunch of questions for you as I finalize my cabinet design but starting with some simple ones –
1. I am considering using the City Cabinet line instead of the Barker cabinet line to save some $. Based on your comparison chart, I feel I would be just fine with everything minus the ability to add the tip-on adapter on the hardware/slides for the trashcan pullout. The comparison chart says that City Cabinets uses Blum Tandem instead of Blum Movento. I am wondering if I could “upgrade” the hardware on just the trashcan pullout to Movento so that I can add the tip-on adapter?
2. I am a DIYer so bear with me – I am having a hard time understanding how the vent hood insert fits into the hood enclosure. I’ve watched the video but I am just not getting how I would screw in the vent hood inserts I have been looking at. Is it common to have to add blocking in the inside of the enclosure to successfully install? Also, wondering if you have an option for the enclosure to be a single panel instead of the 3 panel look? Btw the option in Chief (Barker catalogue) reflects a single panel. If the only option is 3, it would be great to have that modified so renderings are more accurate.
3. Suggestion – the Chief videos you have are great and really helpful, but the new version of the program seems to have changed quite a bit of functionalities. Just a recommendation to maybe re-record similar videos using the updated version of the Chief software.
