Recent Forums BARKER MODERN Roll Out Spacing
  • This topic has 4 replies, 1 voice, and was last updated 4 months ago by Kevin.
Viewing 4 reply threads
    • #3287 Reply
      Adam
        Is there a standard spacing for roll outs when selected for a base cabinet? Can the spacing be customized?
      • #3292 Reply
          Rollouts are evenly spaced, with one located at the bottom and equal spacing between each additional rollout. We cannot modify the vertical placement of the rollouts during production, but you can adjust their positions on site by drilling new holes for the spacer blocks and drawer slides.
        • #3299 Reply
          Kevin
            On that same topic, do you have any recommendations for aftermarket rollouts for the deep wall cabinet upper sections of pantry units? There are tons out there that mount to the bottom and onto shelves, but I’d prefer the sidemounted variety. Thanks
          • #3311 Reply
              Correct, we offer a bottom-mounted pullout, but that doesn’t appear to be what you’re looking for:
              https://www.barkerdoor.com/product-p/rolloutblumotionv2.htm
              Please note that we also sell all the components needed to create a side-mounted pullout that is exactly the same as the ones you have on a past Barker Modern install. However, this setup requires more detailed measurements, as each component must be ordered separately rather than as a complete unit. All components are listed at the following link:
              https://www.barkerdoor.com/Blum-Tandem-Plus-Blumotion-Drawer-Guides-s/118.htm
              You’ll need a pair of 1″ white spacer blocks for each hinged side of the cabinet opening. So, if your cabinet has a pair of doors, you’ll need two pairs of white spacer blocks to ensure the pullout clears the hinges and doesn’t rub.
              https://www.barkerdoor.com/Blum-1-slide-spacer-for-rollouts-p/t59.3570-blum.htm
              You’ll also need one pair of slides for each pullout:
              https://www.barkerdoor.com/21-Blum-Tandem-Plus-Blumotion-Drawer-Guides-p/563h5330b.htm
              And finally, you’ll need a fully assembled, finished, and notched drawer box, as shown here:
              https://www.barkerdoor.com/Baltic-Plywood-Dovetail-Drawer-Boxes-p/drawerbox-baltic-dovetail.htm
            • #3328 Reply
              Kevin
                Great info, thanks so much. I might end up going with the bottom mount option, but I’ll wait until I assemble the cabinets to determine the exact width to order.
            Reply To: Roll Out Spacing
