Recent Forums BARKER CABINETS “Reinforced” for heavy countertops
  • This topic has 2 replies, 1 voice, and was last updated 12 months ago by Chelsea.
    • #2442 Reply
      Chelsea
        I have seen several references to reinforcing your cabinets if doing a heavy countertop. We are planning on doing either soapstone or concrete and are wondering if the standard construction of Barker cabinets is sufficient with the plywood, or if there are other steps we need to take, or max base cabinet widths we need to keep in mind.
      • #2443 Reply
          Our cabinets use 3/4″ thick plywood and are joined side by side, creating a total of 1.5″ thick vertical plywood supports. No additional reinforcement is necessary, as these cabinets are incredibly strong—capable of supporting more weight than you might imagine. We’ve never encountered a single issue, even with the heaviest countertop materials.
        • #2447 Reply
          Chelsea
            Thank you! As I hoped and suspected.
        Reply To: Reply #2443 in “Reinforced” for heavy countertops
