Recent › Forums › BARKER DOOR › Primer only doors
- This topic has 3 replies, 1 voice, and was last updated 2 months ago by
Patrick Manternach
Hello. What type of primer do you use? How many layers? Is the primed surface good to light sand and then paint with water based paint?
We use Sherwin-Williams Gallery water-based primer, two coats on the face and one coat on the back. This process allows for a quality-control inspection between coats to catch any surface blemishes early. The primer is fully compatible with virtually all water-based paints. While we recommend Sherwin-Williams topcoats for the best quality and durability, any high-quality water-based paint from a reputable manufacturer will perform well.
Rod Meade
I need a shaker style door, summit white,
20.5 wide x 21.75 tall . Are the frame styles 2” wide all around?
What is the cost and approximate lead time.
Regards,
Rod -
Our doors are built with 2 5/8″ wide stiles and rails. We don’t offer a “Summit White,” but we do have Primer Only, Pure White, and Dover White. Be sure to order samples so you can review the colors in person.
For quotes, you’ll need to enter the selected options here:
https://www.barkerdoor.com/Shaker-Cabinet-Doors-s/39.htm
