Recent Forums CITY CABINETS Note section willl only accommodate 5 characters (for me)
    • #3462 Reply
      RobCh
        The stainless farmhouse sink I would like to use recommends a 9 1/16″ opening. Elsewhere in the forum I’ve read that you recommend putting dimensions that are not listed in the pull down menu in the notes section. As far as I can tell the note section only accommodates 5 characters. What do you recommend? Thank you.
      • #3463 Reply
          If you need a 9 1/16″ tall opening, just include that request in the order notes at checkout (credit card screen).
          Do not place this in the Notes/Room Tag/ID fields, as those have limited character space and are not reviewed until the order is already in production.
          Small dimensional adjustments are no problem and we’re happy to accommodate those. However, if you plan to modify every item in the order to sizes not listed on the website, that won’t be feasible. As an example, we recently had a customer place an order and then send a spreadsheet with dozens of post-order changes. The request was so extensive and complicated that the order had to be canceled to prevent errors.
          In short: A few changes are fine—rewriting the whole order is not.
      Reply To: Reply #3463 in Note section willl only accommodate 5 characters (for me)
