When installing cabinets between two walls, you really need a transition filler, typically 2″ wide, on each side where the cabinet meets the wall.
Walls are notoriously out of square and out of plumb. Without a filler, the cabinet-to-wall transition can look uneven, and it may limit door hinge functionality. Doors can rub against the wall or leave an inconsistent gap that ends up needing excessive caulking to hide.
We recommend using a matching 2″ wide filler on each side, as shown below, to ensure proper fit, clean alignment, and full door operation.
This reply was modified 1 week, 3 days ago by
