Recent Forums BARKER CABINETS Finished bottom for wall cabinets?
Viewing 5 reply threads
    • #4080 Reply
      Kenschretlen
        I am about to install my wall cabinets and was about to put a finished end on one first as I am up against some trim. As I looked at the cabinet, I realized for the first time that the bottom will have an unfinished edge from the cabinet sides where you could see the plywood construction (only for the very edges of course). Has there been any thought on a finished bottom like the finished edge? I realize that both you won’t be typically looking under the wall cabinets as well as the majority of the base is finished, but thought this was odd and that maybe I missed some finished bottom?
        Thanks
      • #4097 Reply
          Typically, we would add an under-cabinet light valance molding to the underside of the wall cabinets. This hides the light fixtures and cleans up the bottom edge of the cabinets. In this setup, the interior color or material of the cabinet case will still be visible behind the UCL molding.
          https://www.barkercabinets.com/Under-Cabinet-Lighting-Valance-s/70.htm
          You can certainly add a full skin instead. This is done by ordering an additional finished end panel or appliance panel and installing it horizontally. However, this eliminates the ability to conceal the light fixtures beneath the cabinet, so it is rarely done this way.
        • #4109 Reply
          Kenschretlen
            As I installed the cabinets I realize that it really isn’t an issue, but I figured you’d have a solution! If I decide to do something there, I’ll add the valance as you suggested would help too for hiding any lights I may add. Thanks again for your help, and I like the forum, I searched it for my questions, so hopefully others do and find what they’re looking for.
          • #4118 Reply
              All good. Thanks for your business!
            • #4327 Reply
              DVDiva
                I am designing wall cabinets over a toilet, so you will be able to see the bottom of the wall cabinets. I realized that the filler for the sides of the cabinets will allow you to see the gap betweent the wall cabinet and the wall, and of course, the bottom of the cabinet will be maple instead of clearcoat cherry. In this case, should I just order a finished end like you’re saying above to use that as a bottom or is there a different option?
                and should that bottom also be 5/8″ deeper of just be the same depth as the wall cabinets?
              • #4338 Reply
                  Currently, yes, just order a finished end panel and lay it on its side. I will likely add a skin product to the website, but it will be built and priced the same way as a finished end panel laid horizontally, so the end result will be the same.
                  https://www.barkercabinets.com/Kitchen-Wall-Finished-End-Panels-s/97.htm
              Reply To: Reply #4097 in Finished bottom for wall cabinets?
