Recent Forums BARKER CABINETS Design crown molding – flat options
Viewing 7 reply threads
    • #2372 Reply
      Mike Huhn
        We are looking at crown for kitchen cabs (96 inch ceiling height) and we may need to do a flat vs angled trim, due to tie-ins with wall.
        Any ideas of build up that could make the flat molding a little more interesting (and would likely make it easier to run to the ceiling)?
        Do you happen to know how the crown build up was done in this project? https://www.barkercabinets.com/Pasys-Project-s/367.htm
        It looks like a two inch tall cap piece along the ceiling, however I can’t tell how thick it is. I am trying to recreate a similar flat crown with some dimension. Hopefully there is something interesting we could build up with Barker finished pieces?
      • #2377 Reply
          Looks like they used a 4” tall flat molding (regular flat molding from our site) and then added a 2” tall Square Trim to the face. This was likely done to hide an odd gap where the crown meets the ceiling instead of heavy caulking. Looks nice.
          https://www.barkercabinets.com/Simple-square-edge-flat-molding-p/msquaretrim.htm
        • #2378 Reply
          Mike Huhn
            Thanks for the note.
            I did see that 2inch by 3/4 inch piece also, but I am thinking the 3/4 inch depth change might be a bit too heavy of a transition up.
            I just watched the crown molding video posted on the crown molding page and had an idea from your 9inch 3 piece buildup.
            I was thinking that maybe that buildup molding might be a great looking transition on top of the flat base crown molding, after seeing it be the middle piece in the 9 inch crown buildup.
            If we wanted to, I assume we could rip down the height of the 3.5 inch buildup molding to say 2 or 2.5 inches and bring it to the ceiling.
            Do you happen to have any images of what the front profile of the buildup molding looks like?
          • #2383 Reply
              Sure, the build up molding is rather easy to cut down in height. I will see about getting some pics showing it in real life.
              • #2384 Reply
                Mike Huhn
                  That would be great, thank you.
              • #2401 Reply
                MikeHuhn
                  Under the ‘crown packages’ section (https://www.barkercabinets.com/Crown-Packages-s/206.htm) would you be willing to add packages for the ‘Flat’ crown section?
                  Currently, it contains only the single piece Flat Crown Backer piece. Maybe the flat package could be the 3″ flat crown backer piece and the buildup molding piece?
                • #2412 Reply
                    Apologies for the delay. Just returned form vacation.
                    See these images. Is this what you are thinking?
                  • #2432 Reply
                    MikeHuhn
                      Yes, that was the idea … something to combine with the flat crown backer to be able to float along the ceiling.
                      The 3.5 inch buildup looks like it could be a great option for a flat crown with some further visual interest!
                    • #2445 Reply
                    Reply To: Reply #2384 in crown molding – flat options
