Recent › Forums › CITY CABINETS › Base blind corner cabinet
- This topic has 3 replies, 1 voice, and was last updated 7 months, 2 weeks ago by
Pansy Bloomfield
Is it possible to have a blinder corner cabinet with a 12″ blind? Would it be possible to use a Kessebohmer Lemans type shelf in it? What size would the cabinet need to be?
You can request to have the base blind corner cabinet modified to a 12″ blind. While 12″ is not listed as a standard option, because minimizing the blind dimension too much can create an overly wide door that may sag on the blind corner hinges and cause operational issues, we are happy to make the adjustment.
As long as the cabinet isn’t something extreme (for example, 48″ wide with only a 12″ blind), the modification works fine and we’ll gladly make the manual change.
Please include this request in the order notes at checkout (credit card screen).
Pansy Bloomfield
What would the cabinet dimensions be for a 36″ blind corner cabinet with a 12″ return? That is, what would the door opening be, and what exactly would be the return dimension? I understand that the integrated filler would be installed at the 12″ position, but how much more box would there be beyond the 12″?Many of the videos I see online about installing a blind cabinet seems to require that it be pulled off the wall somewhat. It looks like that is to accommodate the return. Can your “blind” area be installed right to the wall?
