Recent Forums CITY CABINETS Apron front sink cabinet dimensions
    • #3278 Reply
      GH
        Could someone confirm my base cabinet dimensions for this 37″ wide apron front sink from Create Good Sinks?
        Link to sink spec sheet: https://www.creategoodsinks.com/cdn/shop/files/5LAS37R-9_Spec_Sheet_2025.pdf?v=13897408959748419841
        2 door APRON FRONT sink base cabinet:
        [WIDTH:39″][HEIGHT:34.5″][DEPTH:24″][Opening Width:opening width= cabinet WIDTH minus 1 1/2″][Opening Height:9″]
        Many thanks
      • #3281 Reply
          Yes, that’s exactly the size I would recommend ordering. This is our newest apron sink cabinet design, and its key feature is the removable upper blank panel. It can be cut and installed after the sink is set and even after the countertop is in place.
          The advantage of this design is that the blank panel can be easily replaced in the future if it ever gets damaged, which does happen over time. Since our cabinets are built to last 50 years or more, having this replaceable panel aligns perfectly with our goal of providing the most durable and long-lasting product possible.
          Just a side note, but definitely worth mentioning. Thanks!
      Reply To: Reply #3281 in Apron front sink cabinet dimensions
