Recent Forums BARKER CABINETS Design Appliance Case Depth
    • #2988 Reply
      firewoodwolf
        Hi Chad and Team,
        I’m considering high appliance stacks and I realized that you recommend 26inch depth for 24 inch depth appliance. I get it is for consideration of the nailer space, but why 2 inch? If the nailer board is about 3/4 why not just say minus 3/4 inch. 2 extra inch sounds like an overkill? For smaller kitchens, 2 inch really means a lot, and I really want the tall pantry front aligns with the base cabinets beside it.
        So, do you have a tighter depth recommended if 26 inch is too much. Is 25 inch acceptable?
      • #3037 Reply
          A 26″ depth allows the countertop to properly terminate into the side of the finished end panel. We made this the standard to avoid having a small, awkward-looking piece of countertop sticking out in the kitchen.
        • #3554 Reply
          Annie
            So is 24” depth Tall and Oven cabinets alright is you don’t have a countertop with those appliances? I will have a drawer/double Oven/microwave, a pantry and a counter depth fridge all in a line (no countertop since I have and island countertop across from them) and was wondering if I should still factor in 26” (I noticed on Chief Architect that these cabinets automatically default to 26” deep). Thanks.
          • #3557 Reply
              I would still use a 26″ depth for all tall cabinets and appliance case stacks. Even if you don’t have a countertop terminating into the side of the tall end panel (as shown in the previous picture), you’ll still benefit from having the extra couple of inches of space for electrical hookups behind your appliances.
              Technically, 24″ depth is fine, and most off-the-shelf cabinet suppliers won’t make anything deeper than 24″ because it causes material-yield issues. The plywood sheets we cut are roughly 48.50″ wide by 96.50″ tall, so you can’t get two 26″ rips out of a single sheet. That means higher material cost for them because they need to cut into an additional sheet and end up with a bunch of unusable strips. We combine multiple orders to maximize every square inch of plywood, so this limitation doesn’t affect us.
              Note that 26″ is our standard depth for tall pantry cabinets, but 24″ will work for most applications. Also, for island installations, I recommend making the cabinets 26″ deep instead of 24″. Historically, this extra depth allowed space for things like downdraft vents or additional plumbing runs in the back of the cabinets. It also gives the plumber more room to work when installing a faucet on a sink located in the island.
          Reply To: Appliance Case Depth
